Converting PAL-DVD to NTSC-DVD
Hello,
I have a PAL DVD movie and i wish to convert it to NTSC DVD.
i have a SONY DVD burner(DRU500A)
any help with this would be appreciated.
thanks in advance
You would need to rip the DVD and re-encode the video again to NTSC.
Ok Ok Ok, I know I'm not as smart as all of you. But look how much smarter I make you look! -
thanks for your reply.
i tried that but still my DVD player couldn't play it.
also it's supposed to be Region free (though the PAL DVD is from Europe)
may be I am missing something here?! -
Well if you were able to rip the DVD, then your DVD-Rom drive was either region free, or the same region as the original DVD. Most aps like Smartripper will remove the regional code anyways. But when you burn the DVD, I seriously doubt your authoring ap put any regional code at all. So your probly using a region free DVD-R anyways.
BarneyOk Ok Ok, I know I'm not as smart as all of you. But look how much smarter I make you look!
Converting Pal DVD to NTSC DVD with Menus
By LouieLou in forum Video ConversionReplies: 6Last Post: 9th Oct 2010, 17:01 -
converting PAL DVD to NTSC while preserving chapters
By andreyvul in forum LinuxReplies: 10Last Post: 2nd Sep 2009, 04:04 -
help on converting an entired pal dvd to ntsc dvd
By supersam in forum Video ConversionReplies: 6Last Post: 17th Feb 2009, 22:55 -
converting PAL AVIs into NTSC DVD
By exekutive in forum ffmpegX general discussionReplies: 0Last Post: 24th Jun 2007, 19:20 -
Converting an NTSC DVD to PAL w/ DTS
By thisismyname07 in forum Authoring (DVD)Replies: 28Last Post: 27th May 2007, 00:57
