is it possible to use this http://www.directron.com/cd509u2.html external enclosure to house a Sony DRU500AX? will this work properly? and also would this wokr on a mac? if so what kind of software would i need. thanks in advance.
Nothing inherently wrong with these enclosures, only thing is don't use them with USB 1.x ports, you will be handicapping the device, use them with a USB 2.0 port you have (if not buy a USB 2.0 Add-in PCI card). firewire version these enclosures should also work.
Supposedly USB 2.0 is equal in speed to Firewire, I've never compared them side by side so assuming they are equal.Cendyne/Pioneer 105 & 104 with a Dazzle* Hollywood DV-Bridge. -
Actually USB 2 is supposed to be faster then Firewire. I'm using my Pioneer A03 in an External ADS/Pyro enclosure. My enclosure suppoerts either USB 2 or IEE-1394. I have had a few failed burns using the USB connection, but never had an issue using Firewire. I don't care that USB 2 is faster then Firewire. Firewire is much more stable and dependable IMO!!
Barney
PS:
One downside is that Pioneer tells you that if you use an enclosure, not to do any firmware updates. You need to connect the drive to your actual IDE controller for them to work correctly.Ok Ok Ok, I know I'm not as smart as all of you. But look how much smarter I make you look! -
so the enclosure i posted would work great.
is not post ones that would work fine. thanks fpr the replies so far.
i have a same enclosure working...it works ok..but i would recomand a firewire enclosure with oxford 911 cheapset..
Nexstar Enclosures Question
By mn072065 in forum DVD & Blu-ray WritersReplies: 4Last Post: 29th Aug 2011, 13:58 -
Any external SATA 3.5 enclosures with auto-shutdown
By jntaylor63 in forum ComputerReplies: 2Last Post: 15th Jun 2011, 20:32 -
External Enclosures Recommendations (?)
By Seeker47 in forum ComputerReplies: 1Last Post: 2nd Dec 2010, 21:39 -
Enclosures with FireWire IDE or SATA?
By Sakuya in forum ComputerReplies: 15Last Post: 20th Jan 2009, 19:44 -
How to set up multiple external HDs in enclosures
By robjv1 in forum ComputerReplies: 6Last Post: 18th Dec 2008, 10:03
