Hello ,
I want to preview a DVD-Image, before I burn it.
Allways doing so, when I create SVCD's.
Checking the Image is nearly what you get in your standalone.
You can check the proper funktions of your menu , picture Qualitiy ,
different soundchannels ect.
Which programms do I need to create the DVD-Image , checking it using a
Soft-DVDplayer that opens the DVD-Imagedrive, burn the image.
I tried this with Nero 5.5.8.2
At first I created an image using the template DVD-Rom (UDF)
and there UDF 1.02 as physical partition.
The DVD-Imagedrive contained the structure VIDEO_TS with the VOB BUP and IFO -Files
But WinDVD was not able to open this Drive as a normal DVD.
The first try went wrong , the DVD was only playable in the Softplayer,
I think because I used UDF 2.01 .
greetings
Bernd Kochs
Results 1 to 1 of 1
Create PS3 readable HD movies split over 2 DVD-9s?
By darrellr in forum Authoring (Blu-ray)Replies: 1Last Post: 8th Jan 2012, 10:08 -
make external DVD drive readable to media player?
By maca in forum Newbie / General discussionsReplies: 3Last Post: 4th Dec 2011, 19:57 -
unreadable DVD becomes readable - why? how?
By JohnnyBob in forum Newbie / General discussionsReplies: 3Last Post: 4th Jun 2010, 17:11 -
Only First Session readable on DVD Player-- Deep Burner
By deepakOne in forum Authoring (DVD)Replies: 1Last Post: 27th Oct 2008, 02:13 -
DVD Writer recognized as Readable Only Drive!!
By lawrence_shin in forum Authoring (DVD)Replies: 1Last Post: 1st Jun 2007, 04:15
