Hi guyz.
I looked but couldn't find this error on another forum so forgive me if it is in the wrong place. Now i get the abovementioned error everytime i try to convert a dvd to avi using DVDX2.0.
I'm fairly new to all of this so i'm thinking it might be some codec problem. I d/l "Ultimate XP DivX Codec - Nimo 4.3.3" to cover all my codec needs but with still no luck.
Any chance you can help me with this problem. It will be much appreciated.
Thanx in advance!!!!!!!
i wouldn't use dvdx.
dont use any codec pack.codec packs are just filters for veiwing avi's.they just cause problems any way.
you need to install the codec it self to encode.
install the divx pro or xvid codec(dont use divx 5.03)
i would say start off useing divx 5.02 with gordian knot .27 http://www.doom9.org/gknot-main3.htm
i use divx 5.04 with GK .28 beta which supports divx 5.04 and xvid,but i been ripping a while and is a little more advance -
Ok thanx zodiac
I'll give guardian a go. I'll message back to see how i went. Thanx once again
DVD Decrypter error:Failed to set data for "DVDDecrypterPlayMovieOnArr
By rachelsmiley in forum DVD RippingReplies: 17Last Post: 22nd Dec 2017, 12:40 -
Can't set audio in .avi format in Vegas 9.0
By InsaneShadow in forum EditingReplies: 1Last Post: 24th Aug 2010, 01:05 -
How can I set the default audio stream of a .VOB file?
By knn in forum EditingReplies: 9Last Post: 19th Jan 2009, 20:10 -
Dar failed to set in MeGui
By AussieHusky in forum DVD RippingReplies: 0Last Post: 22nd Feb 2008, 04:46 -
failed to connect Output pin 0x0093ae4c ["Stream 00"] on AVI Spli
By carcrashhearts in forum Newbie / General discussionsReplies: 2Last Post: 9th Nov 2007, 13:46
