First: I want to buy a DVD-ROM, but i donīt which (Aopen or and AcER)boths DVD-ROM(16X),CD-ROM(40X)? somebody can give me an advice.
Second:I transfor some movies to VCD format, i am using TMPEnc the last version, and the result of the conversion are not bad, but i think that could be better, i am using a video card with 4Mb AGP, if i change the video card to better with more video memory, the quality of the result video can be better? The quality of the result video are very closely related to the video card?
Best Wishes
Gabriel Fanilla
Good Luck -
Ok for starters, most of the Aopen and Acer DVD drives are in actuallaty a Pioneer OEM Drive, so you might as well buy a Pioneer for cheaper! the 106S model (slot drive 16x/40x) costs 54$
Now as for ripping, all the DVD's will give you the same quality when ripping, however, playback has nothing to do with the drive, it could be the quality of your card and monitor, and of course also the Playback software you are using.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
My system is built with a SOYO motherboard, PIII 450 Mhz, 64Mb Ram and 6Gb HDD, Video Card Trident 4Mb.
Tell what hardware i have to change or upgrade if i want to get excellent results in formats coneversion.
Tell me the best Playback software for this goal.
The best software for farmats conversion (VCD,Divx and DVD)
Tell me the hardware that you recommend me (Video card)etc.
Best Wishes
Gabriel Fanilla
Good Luck -
Tell me about your conversion machine configuration, what i need!
Best Wishes
Gabriel Fanilla
Good Luck -
This is more or less the system I have at home, but you really don't need something like it:
EPoX 8KTA3 KT133A chipset
AMD Thunderbird 1000Mhz CPU
384mb SDRAM PC133
2 x 45gb Western Digital HDD
Pioneer 106S 16x/40x DVD-ROM
Sanyo BP1400P 16x/10x/40x CDRW
GeForce2 MX400 with TV-Out
The only thing I would tell you to change would be your Trident 4mb card, you can buy a cheap GeForce2 MX200 for as little as 50$ to 60$, and it will be well worth it, i'm not a gamer, and I did not find spending over 100$ on a graphics card, so I bought the best cheapest one I could get, and quality is great.
As for playback software, I always use PowerDVD, because I find it's playback quality to be one of the highest, although WinDVD has more support for SVCD for example, it's playback is rather bad in my opinion.
Best Regards,
Sefy Levy,
I have to change the wires of my cd readers (DVD and CD-RW).
I have a LG CDRW (8x4x32x).
Which programs you used for a complete rip DVD and burning method?
Tell me something more
Mpeg 4 = Divx?
MPEG 2 = are?
Best Wishes
Gabriel Fanilla
Good Luck -
MPEG-4 is MPEG-4. DivX is based on a type of MPEG-4 video.
MPEG-2 is MPEG-2. Both DVD and SVCD use MPEG-2 as the basis for encoding the video.
Regards.
Michael Tam
w: Morsels of Evidence
CD-ROM vs. DVD-ROM
By Judson in forum MacReplies: 10Last Post: 6th Apr 2012, 09:33 -
DVD-ROM Backup
By 329329 in forum Authoring (DVD)Replies: 2Last Post: 11th Mar 2010, 13:24 -
CD \ DVD ROM not seen in Windows
By lacywest in forum ComputerReplies: 1Last Post: 16th Oct 2009, 10:19 -
dvd rom discs
By johnbud in forum MediaReplies: 3Last Post: 26th Jul 2007, 07:03 -
hd-dvd rom drive
By computerchuck in forum Software PlayingReplies: 6Last Post: 8th May 2007, 08:55
