  1. If anyone has been down to www.whatisthematrix.com lately they might have come across their excellent (1000 x 540) MPEG4 *.mov of the MATRIX RELOADED FINAL TRAILER. I have. I would like to encode it to MPEG2 as a high bitrate XSVCD. I've checked out the guides. I've tried things out. I can't seem to get the damn thing to work.
    Allegedly my DVD player (RCA RC5240P) can play XSVCD with bitrates as high as 6000-8000kps. Myself, I've never been able to get it to play anything over 2500kps (XVCD or (X)SVCD). I use TMPEGEnc to do the code. I use VCDEasy and Fireburner to do the burn.
    What could I be messing up? Can I retain the high quality of the source with a lower (svcd compliant) bitrate? The burns I've made of a 4500kps XSVCD recode have the most astounding picture quality (sound quality is iffy due to my lack of audio engine on TMPGEnc) BUT...they jump!!!
    MY TMPGEnc RECODE SETTINGS
    VIDEO STREAM -
    Stream Type: Mpeg2
    Size: 720 x 480
    A/R: 16:9 Display
    Frame Rate: 24fps (Internally30fps)
    Rate Control Mode: 2 Pass VBR
    Bitrate: Avg - 4500kps, Peak - 6000kps, Low - 2500kps
    Profile & Level: MP@ML
    Vid Format: NTSC
    Encode Mode: 3:2 pulldown (playback)
    YUV: 4:2:0
    DC Comp: 10bits
    VIDEO SOURCE SETTING -
    Video Source: Non-Interlace(progressive)
    Field Order: Bottom First (B)
    Source A/R: 1:1 VGA
    Video Arrange: Custom Centre (720 x 384)
    Other than that, I performed a very slight colour correct, and that's it.
    I'm not a total idiot, but I don't cap, and therefore I don't do this sort of stuff every day. I've fussed with it but I just can't seem to get this right.
    Do I have to use the Inverse Telecine feature? (I hope not) The source is 24fps, so I thought I wouldn't, but I wouldn't know; I've never needed to use it in the past.
    Please Help me,
    - BriX
  2. "Allegedly" is the keyword. I heard people say their players can play 720x480(576) XSVCD at 4-7Mbits/s all the time. But my player began to stutter at only 2900kbps, with only 480x480! I am highly suspicious of such claims. Can you read CDRs at 4-5Mbits/s? I don't know.
    So you need to find out what the real maximum bitrates for your player is.
    The only problem I can see with your encoding settings is that your field order might be wrong. For film sources, it usually is top field first.
