  1. CPU: AMD Athlon XP 1800+
    RAM: 512 MB DDR SDRAM
    Device: Leadtek Winfast TV2000 XP Deluxe
    Programs used: Winfast PVR and Virtual VCR
    Video codec: HuffyUV
    Audio: MP3 320 KB/s
    Resolution: 720 x 480
    FPS: 29.97
    I have a very strange problem (probably the only one out there that experiences this), and I haven't found anything online about this. When I stop a video capture that's about more than 17 minutes long, the program(s) I use freezes up. I am forced to close the program. The video itself (the one that was just captured) is still there, so I play it. After about 16 minutes or so, the audio cuts off (it's complete silence). Why is this happening?
  2. I think I know what to do next time. Instead of capturing the audio as an MP3 format, I'm going to capture as a PCM format. Do any of you recommend capturing the audio under the PCM format?
    Dec 2002
    Texas USA
    No, not usually.
    Try it anyway, I guess.
    Testing never hurts.
    I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored.
