Hello all
I took a dvd and converted it to svcd with forty two
only problem is....... the first .bin/.cue is 805 (ok) the 2nd is 835 (not ok)
i thought id just run the .mpeg which was the movie file forty-two made as a temp though ffmpegx at a slightly smaller bitrate to make the last .bin 805.
problem is, it only made the audio! not the video, saying there was no .mp2 located.
i assume i need to extract the audio from the .mpeg to do this!?!
Is this right?!?
is there another way to do this!?
Results 1 to 1 of 1
Want to change a bunch of mp3 files to smaller bitrate
By happydog500 in forum AudioReplies: 6Last Post: 11th Aug 2009, 12:08 -
Converting MPEG into a smaller file size?
By ione in forum Video ConversionReplies: 3Last Post: 9th Sep 2008, 22:36 -
Archiving Video - Smaller than DV better than MPEG-2?
By boblin2 in forum Video ConversionReplies: 30Last Post: 21st Apr 2008, 04:27 -
Smaller MPEG-2 Files?
By DigitalSounds in forum Video ConversionReplies: 12Last Post: 30th Oct 2007, 03:55 -
Help in making MPEG-2 files smaller with encoding
By screwed in forum Video ConversionReplies: 4Last Post: 20th Jul 2007, 03:23
