I've had trouble burning VCDs (pixelation, blockiness etc) due to problems with my burner, but I discovered that I can just simply copy a Mpeg file onto a CD with nero and my DVD player will play it (no menus or chapters, but at least it plays it without problems).
My question is this: Previously I would convert my avi files using DVD2SVCD with a 800 CD size setting on the bitrate tab. No problem with VCDeasy, but now that I'm simply copying the mpeg file onto a disc will the fact that the file is 790MB be a problem? Or does the "its not the megs but the minutes that matter" rule apply in this case as well?
Many thanks in advance,
JDC
unless burning as VCD it must be under 700mb, unless you can overburn or have higher than 700mb media.....
Got it - thanks. So what setting should i use on the bitrate tab? 740? or should I enter 700 manually?
Simple way to join mts files with stream copy (no recoding)?
By MJ Peg in forum Video ConversionReplies: 32Last Post: 1st Oct 2009, 08:29 -
GOP length and filesizes (HCenc)
By Movie-Maker in forum Newbie / General discussionsReplies: 4Last Post: 19th Nov 2008, 11:41 -
Sony Vegas Rendering large filesizes!
By HelponvidVeg in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jul 2008, 16:58 -
Dont get how to apply filter to a MPEG-2
By noob4ever in forum Newbie / General discussionsReplies: 2Last Post: 3rd Mar 2008, 21:01 -
How does it work from .avi to DVD with filesizes
By herbster in forum Authoring (DVD)Replies: 6Last Post: 10th Dec 2007, 20:17
