I've got a problem with svcds that I burn from bin/cues made by CopyDvd. I put them in my standalone Phillips (DVDQ35) and the sound and video stutters.
I don't have this problem when I put the DVD in my computer's dvd player.
I don't have this problem with burns I make of others' bin/cue files. Those SVCDs and VCDs play just fine in it.
I figure it's got to be a settings issue. Here are the default settings of CopyDVD (in case you don't know them) that I don't know enough to change:
Video Bitrate - 2376
Frame Rate - 23.976 (NTSC)
Audio Bitrate - 224
Aspect - Letterbox
iDCT - Best quality
Detect progressive NTSC is checked
Audio Video - 480 x 480
Quality - Medium
CopyDVD (and DVD2SVCD, for that matter) has trouble recognizing my drive, so I just go ahead and use Alcohol to burn from the bin/cues. I have tried both my regular max burn speed of 16x and have taken it down to 4x but got the same result.
Where am I going wrong?
Thanks for your help.
Results 1 to 1 of 1
Bobby
Sound is stuttering
By GeordieDave in forum Newbie / General discussionsReplies: 7Last Post: 19th Apr 2011, 18:21 -
Phillips DVP5990/F7 and .AVI - video is Ok, but no sound
By PaulGor in forum DVD & Blu-ray PlayersReplies: 10Last Post: 16th Apr 2010, 13:12 -
Playback of DVD authored with multiple angles has stuttering sound
By kipling100 in forum Authoring (DVD)Replies: 2Last Post: 14th Nov 2009, 22:54 -
Phillips DVP5982 vs Phillips DVP5992?
By jarko in forum DVD & Blu-ray PlayersReplies: 4Last Post: 12th Jul 2008, 13:41 -
Phillips 5982 - Which receiver inputs for sound when using HDMI ?
By Fearnot in forum DVD & Blu-ray PlayersReplies: 19Last Post: 13th Dec 2007, 17:45
