I Have Just Purchased A Pioneer DVR-105 (FM1.30), After reading Just about all the help files and tutorials that are about I thought I stood a fighting chance of backing up DVD - How wrong could I be!!!
Ive been DVD-SVCD for ages so I wouldnt say I was a noob but - this is really drivng me mad.
I hope someone can help
I have used variations of the following progs to burn a working DVD-r but with little success.
DVDShrink / imgtool / DVD Decrypter / DVDx / Nero 5.5.10.15 / Disc Juggler / Instant copy 7
Out of 30 DVD-r writen only 2 work in my Standalone Sanyo DVD-7201
I have checked with this site and my standalone supports DVD R/W
and i have never had probs with VCD/SVCD.
I thought it could be the media, I have tried Datawrite (Princo) 1X and 4X
with no luck so I changed to ONE (Ritek) with still no joy so I bought some DVD R/W to save on coasters (I currently havnt got enough cups to the fill the coasters) and they didnt work either.
Ive tried to backup DVD5 and DVD9 to one DVD-r and everying goes fine no matter what I use but the DVD just wont work in my player - HELP ME PLEASE!!
Just a couple of points: I have tried half a dozen other princo 2X DVD-r that someone else wrote on either an A04/A05 and they work fine.
I tried loads of combinations of software and 99% worked on my pc just not on my SA unit
The very last thing i am trying is burning in Nero Using UDF 1.02 instead of 1.5.
and if this doesnt work....
Sorry to drag it out but I need some serious help
Trying my discs on another player was another option i am going to try, i did think of it and will, but given the ibfo that on this forum my standalone get some good write ups for compatabilty and 95% of ppl play DVD R/W on their sanyo dvd 7201, plus the fact other ppls disc work on my machine - i didnt think it was my machine at fault.
Tnanks for the advice - it can only narrow the options down for me.
BTW I burned my THIRD (out of 30) DVD-r last night!!!
Using the nero UDF 1.02 option - was this just luck or is it solved?
I used DVD Decrypter to hard drive in file mode (select only movie files)
Used DVDShrink to get movie to correct size (level 1 compression)
Burned with nero (udf 1.02)
this works but , Is there a way to burn an image file in this format, what happens if I want to author my dvd and put on a menu etc. Does having a menu mean I have to create my movie as an image file then burn?
Are there any progs that allow me to burn an image in UDF 1.02?
thanks -
Forgive my ignorance but, to burn an image file in nero i use the DVD-ROM (ISO) or DVD-ROM(UDF/ISO) or in nero express DVD image.
am i right in thinking the default setting is UDF 1.50?
if it is, how do i burn an image in udf 1.02
thanks
What if the Matrix ran on Windows
By freebird73717 in forum Off topicReplies: 3Last Post: 12th Nov 2008, 19:29 -
I have ran a DVD through DVD Shrink, but it came out in 2 parts. What 2 do?
By ZQ8_Blazer in forum Newbie / General discussionsReplies: 6Last Post: 9th Jul 2008, 23:28 -
Weird frame rate issue. Anybody ran into this before?
By dimtim in forum Video ConversionReplies: 4Last Post: 19th May 2008, 07:21 -
DIRECTV options?
By FatFreeVW in forum DVB / IPTVReplies: 0Last Post: 23rd Nov 2007, 14:48 -
what are my options
By bmw2007 in forum Video ConversionReplies: 2Last Post: 26th May 2007, 07:54
