Hi!
I'm trying to import at subtitle file into SubtitleEditor, but it just doesn't work. I've searched through this forum and saw that it would work if the subtitle was imported into TitleLAB and then saved.
When I look at the file it looks like it's in QuickTime subtitle format, but I guess that that's the format that SubtitleEditor uses. When I try to import the file absolutely nothing happens. I can select the file in the File dialog, but then it displays a box called "Conflict solving"; nomatter what I select in that box it just doesn't do anything...
Can anyone help me on this? How do I import a subtitle file into SubtitleEditor? On my PC I have an application called Subtitle Workshop which can open/save a lot of different formats so it should be possible to get a file in the right format; I just need to know which one is the right one!
Regards,
rfn![]()
Results 1 to 1 of 1
subtitleeditor
By butterflies in forum Authoring (DVD)Replies: 1Last Post: 7th Dec 2009, 01:02
