I want to capture my Powerpoint presentation to burn on a DVD. The Powerpoint presentation has animations and all so I can not just export to picture files. And I have tried screen capturing programs, they are no good for me, because the Powerpoint presentations have a lot of high-quality pictures in it which affects the performance of the snap shot program.
Ideally what I want to do, is send a live feed from my computer screen and capture to my DV camcorder. Then capture that video from the DV tape back to avi, then to DVD. The connection that I am using is a firewire cable. Is it possible to enable it as a live feed of my computer screen? That would be perfect for me.
-Machine
Depends on what Version of PPT, and what OS you have. PPT for OSX Mac will export to QT. PPT 2002 or XP may do AVI through Producer.
Nonetheless, it is probably much easier for you to send a feed out through your video-out to the DV camera.
Scott -
I have a feed out, but it is firewire. Is it possible to send a live feed of my computer screen out through firewire?
-Machine -
Mayb try this caputure program I think it works great. I use it to caputure instruction videos for Pro/Engineer (a 3D-CAD program). I don't think there is a way to stream the power point presentation out thru firewire.
http://www.atomixbuttons.com/vsc
Capturing clips from DVD's to embed in PowerPoint presentations?
By billy_ball2 in forum Newbie / General discussionsReplies: 6Last Post: 23rd Aug 2013, 11:27 -
Powerpoint to Video Help
By annieo in forum Newbie / General discussionsReplies: 1Last Post: 2nd Aug 2009, 08:23 -
How can I Put PowerPoint on a DVD?
By jrhx in forum Authoring (DVD)Replies: 35Last Post: 26th Jun 2007, 13:07 -
DVD with videos and Powerpoint
By RobertUSM in forum Authoring (DVD)Replies: 6Last Post: 15th May 2007, 10:40
