  1. Hey Guys,
    Having a weird problem when it comes to ripping a DVD. Used DVD2DVDR to rip and encode the main movie and authored in DVD Maestro. Took out original movie VOBs and replaced with re-authored ones and ran IFO update. In PowerDVD the final product works perfectly, but when I burn the DVD in Nero it works in PowerDVD but the menus do not function properly on both my standalones. I tried imaging the DVD using ImgTool and burning it with DVD Decrypter but the same problem occurs. I also tried using InstantCopy to rip the DVD without the extras I wanted, and replaced IC's main movie with the one I authored and running IFO Update, but the exact same problem occured. If anyone knows how I can fix this, or what I can use to burn the DVD please respond, help would be appreciated,
    Thanks,
    PS. I tried both PowerDVD and WinDVD when playing the DVD off the hard drive and they both played it fine. I also tried "Getting VTS Sectors" manually using IFOedit on the final product as well with no luck.
    Dec 2002
    Texas USA
    Too much customizing, you did something wrong. DVDshrink will be fine for removing and/or shrinking size. Try that instead.
    I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored.
  3. So use DVD Shrink, instead of IC and replace the main movie from the DVD Shrink product with my authored main movie?
