hi, i have been given an old MM100PCTV card and have managed to install, find drivers and get it working. i've managed to capture some t.v to my hard disc although i had to use windows movie maker and therefore .wmv format. my question is this: can i use this card to capture some vhs movies i have and want to put onto disc and what other software can i use apart from windows movie maker. thanx for ur advice
If you can capture with Virtualdub, that's a great application.
I've had good luck with VirtualVCR as well. Both are freeware.
for editing, again, Virtualdub can do it, but it's very linear. For non-linear, you can use MovieXone, their basic version is freeware. (basically limited to one audio and two video tracks, if I'm remembering correctly).
Check the Tools section and the Capture, Convert and Burn sections for more good info.
- housepig
Question on VHS Capture vs DV Transfer to PC
By VideoTechMan in forum Capturing and VCRReplies: 36Last Post: 3rd May 2012, 05:57 -
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 15:52 -
Dumb question on improving video for capture from VHS tapes
By lewist57 in forum Capturing and VCRReplies: 13Last Post: 2nd Jul 2010, 11:26 -
Which $150 or under capture card for VHS/S-VHS -> computer?
By HDClown in forum Capturing and VCRReplies: 25Last Post: 16th Apr 2010, 22:16 -
VHS to DV capture: Component video vs. S-VHS
By vega12 in forum Capturing and VCRReplies: 8Last Post: 19th Feb 2009, 19:42
