Hi!
I know this sounds a bit strange, but how do I rip the audio stream from a dvd only, without having the movie? I´m learning spanish right now and a very good method is to watch the movie in your own language first and then in that foreign language. Later on you just play the audio file while doing something else and your brain will automatically catch the audio from the movie and "save" the words.... this is a very successfull method, I´m just to lazy to record the sound from my tv set and I´m sure there is a way to rip the audio streams on a dvd seperately...
Thanx
Cat
try using dvd2avi to strip the audio file and you might want to use cool edit pro to edit the audio file before buring to a regular cd...
just my 2 cents -
..or you can use DVDDecrypter>select Stream Processing>select Demux to new vob>use BeSweet to convert to .wav>burn to CD.
I agree with moviegeek, easiest way is to use Decrypter, it can rip it right out for ya.
I found the easiest way myself.... a programm called Clier´s AC3 tool... rip the AC3 stream directly from the vob of the DVD and then converts it to wav -> mp3!
thanx for your support
cat
Is there really no application that can ripp/save this video ?
By harry88 in forum Video Streaming DownloadingReplies: 4Last Post: 5th Mar 2012, 13:05 -
BD ripp for edition in vegas -
By Klemc in forum Blu-ray RippingReplies: 10Last Post: 4th Aug 2010, 00:48 -
Bluray ripp to lagarith 720x405 resize VirtualDub
By Klemc in forum Video ConversionReplies: 13Last Post: 4th Aug 2010, 00:45 -
what is the fastest software to RIPP into H264 ?
By james_patageul in forum DVD RippingReplies: 8Last Post: 12th Apr 2010, 13:46 -
ADVICE needed plz! As of Feb 08, best format to ripp DVDs? TIA.
By carapalida in forum Newbie / General discussionsReplies: 3Last Post: 13th Feb 2008, 12:11
