    Oct 2002
    INdiana
    I got 2 questions hopefully someone can answer.
    First is on DVD2one. If i have a DVD thats under 4.37 gigs like Days of Thunder. If i used DVD2one on it (movie files) will that mess with the resolution even if its under 4.37gigs? I was wanting movie only(3.9gigs) on a dvdr so i used DVD2one.
    part 2. Same movie as above. After i ripped the whole movie and played on ifoedit, it comes up with the wrong region screen. Why is that if i live in region 1? I use ifoedit to region free it, then save it. I play it and it comes up with the wrong region screen again. So i go aback and go thru each VTS to make it region free. I just dont understand why it shows that if the disc is reg.1 and dvd player is reg.1
    thanks!
  2. Member wulf109's Avatar
    Jul 2002
    If a disk is 4.37GB's or smaller there's no reason to us DVD2ONE. Rip it with DVD Decrypter in files mode. DVD Decrypter will create a VIDEO_TS folder on your HD. Then just burn it with Nero.
    Oct 2002
    INdiana
    Well if i want the movie only on it i use it to make things quick. I was having problems with the region1 code on the dvds. Days Of Thunder wouldnt play on my DVD player after burning. Saying it was not the correct region. The dvd is reg.1 and my player is reg.1.
