Hi everyone !
I just converted an AVI movie file , I think it is DivX , to a VCD mpg file using TMPGen ... after it finished the conversation ... there was no sound to hear , nothing to hear .. just the video withought any sound ..
Any Idea ?
Thanks for any help !
Check out this post: https://www.videohelp.com/forum/viewtopic.php?t=154139
Also, try searching the forums, you'll get lots of tips.
"Art is making something out of nothing and selling it." - Frank Zappa -
Thanks alot ZippyP. for the tips ..
I really searched too much in the forum and in the main website, the only thing which i found to end my problem was using avi2wav programm to extract the sound as wav , I did that exactly after I posted my Topic , then I found your tipps , which say to chick the avi file using Virtualdub , I will follow now this thing to chick if there is any bad frame or something like that ..
Thanks -
did you check the video you made in media player for the audio stats to see if is there? what format did you feed to TMPGENC for the video, was it wav?
In tmpgenc you have to tell the program where toolame is on your computer for it to convert the audio to mp2, if you didnt then it will use its in-built engine for conversion.
Best way is to remove the audio as mentioned earlier as wav file in vitualdub, then download toolame and toolame GUI place then in the same folder and run toolame gui, if you want SVCD then check (224 bps audio) for output.
then multiplex using TMPGENC mpeg tools (file-mpeg tools-multiplex) and add both video and audio, select SVCD from the drop down box (or look on this site for info on the svcd header trick. This can fool DVD players into thinking your video is a VCD and will play your SVCD (in SVCD quality) even when your DVD player wont support SVCD´s
I´ve done the above lots of times and has always worked well.
Good Luck, You wont need it.
tsMuxeR not converting sound
By mysts in forum Video ConversionReplies: 5Last Post: 16th Jan 2011, 21:30 -
AVI converting sound issue
By wickerstick in forum Video ConversionReplies: 1Last Post: 23rd Jul 2009, 07:53 -
No sound after converting/ripping
By breezestar in forum Newbie / General discussionsReplies: 8Last Post: 30th Jan 2008, 11:08 -
No sound when converting DVD (VIDEO_TS)
By jompa in forum ffmpegX general discussionReplies: 3Last Post: 18th Oct 2007, 17:48 -
Loss of sound after converting with WinAvi
By TheGift73 in forum Newbie / General discussionsReplies: 1Last Post: 4th Aug 2007, 10:26
