  1. I need some tool to convert my dts track in the ripped vobs i've on my hard-disk ... do tell me how .. the only ac3 track available is in chinese thats why im on the lookout for dts to mp2 converters ..
  2. Member adam's Avatar
    Sep 2000
    The latest version of dvd2avi can decode DTS tracks to wav. From there you can encode to mp2 using toolame.
  3. well i can demux dts track using dvd2avi alrite .. but cant get it out in wav .. when i select that option 'decode to wave' in dvd2avi no wav file is formed only project file is made ... is there a tool for converting .dts files to wav, mp2 or mp3 .. ?
  4. is there a tool for converting .dts files to wav, mp2 or mp3 .. ?
    Tadam ! yes, mine !
    you have to install WinDVD4 because it install in your system a
    filter named: Intervideo Audio Decoder. This piece of filter can
    decode AC3 and DTS.
    then download the free filter named DTSSource
    then install my freeware: Hypercube Transcoder 3.0
    with this tool You can produce MPEG Mutlichannel or 6 RAW PCM files.
    Note: HT3 only support 48Khz as input for instance.
