Can anyone help I keep getting a blue screen and the encoding stops Half way through encoding a video I have downloaded. anyone got any ideas of the reason for this and how to correct it, or is there a better tool for encoding to mpeg more reliable than this one, seems I am not the only one having problems with it.I have deleted and re-installed but this does not solve the problem, thanks in advance
mick
Blue screen, do you mean that your whole system crashes or just TMPGEnc locking up?
"Art is making something out of nothing and selling it." - Frank Zappa -
just blue screen and then tmpgenc crashes,if I hit enter takes me back to windows and the encoding has stopped
Check out this page: https://www.videohelp.com/tmpgenc.htm Scroll to the bottom for TMPGEnc problems. Also, did you scan and remove bad frames?
There's this: https://www.videohelp.com/forum/viewtopic.php?t=152458&highlight=idiots+guide
or this: https://www.videohelp.com/forum/userguides/153907.php
or this: https://www.videohelp.com/forum/viewtopic.php?t=142555
Take your pick!8)
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
Tmpgenc Plus & TMPGEnc Batch List Creator help Please
By VOYAGER2009 in forum Video ConversionReplies: 2Last Post: 4th Jul 2010, 07:57 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
