    Sep 2001
    Australia
    Hi there im relatively new to converting DVD's to SVCD and i notice that my licence for TMPGEnc is about to run out. How do I go about registering. Also if i am encoding a region 1 DVD do i use the NTSC or NTSCfilm template at the moment i have only dealt with region 4 or pal dvd's so that hasnt been an issue.
  2. For now you have to update every month (see update dates) or get version 12a
  3. OOOps! Just found this
    Vejita-sama
    Member
    Posted: 2001-09-07 12:40
    The 30 day limit can be reset by deleting the following registry key:
    HKEY_CLASSES_ROOT\CLSID\{63902277-B101-4049-8B46-C24B67E155E5}
    Or, make a file "TMPGEnc_MPEG2_Reset.reg" with the following content:
    REGEDIT4
    ; Enables TMPGEnc's MPEG-2 encoder for 30 more days.
    [-HKEY_CLASSES_ROOT\CLSID\{63902277-B101-4049-8B46-C24B67E155E5}]
