hello to all i have a pinnacle pctv card with with S-Video and Composite inputs when ever i play my tv the card works great it captures great movie and sound but when i join my camcorder or vhs vcr to svideo input the video is clear but there is no sound pls do help in details thanking u hello
(i have the latest pinnacle and sblive sound card drivers here is url of the card wich i have http://www.tv-cards.com/pctv.php pls do help in detail) thank u again
chant chant chant gods name
make sure your inputs are set correctly on the bottom right by your clock. the play and record settings sometimes mess me up.
i would stop using the pinnacle drivers. there are universal drivers available that are much better. with the new drivers i can capture at 720x480 and 29.97fps without any dropped frames. the pinnacle drivers didn't support that high of a resolution and are crippled in other ways too i believe.
do a search on google for universal bt8x8 drivers. that's the chip that your card uses. then you won't be able to use the pinnacle software but there is much better freeware available anyway. amcap, dscaler, virtualdub are some examples. -
thank u don for helping ,don i have used third party software like windvd recorder it has detected my card my tv caputer works well sound and capturing both but again when i go to svideo the same thing happens only movie no sound and could u pls guide me for some othe best software shareware or freeware do help thanking u hello
chant chant chant gods name -
http://www.fgeng.com/drivers.htm#univwdm
i think those are the same drivers i use towards the bottom of the page.
i have used a program called amcap.exe for captures and also virtualdub for captures. both work good for me. dscaler works good for watching tv. i believe there is a modified version of virtualdub called virtualdubVCR which you can time record things off of tv signals.
do you have the svideo in the capture card, and the sound going into the "line in" on the sound card? then make sure "line in" is selected as the input for the sound card.
can't think of what else would be causing the problem. my capture card has a sound output but no line in, so i use my "line in" on the sound card, like i mentioned earlier.
hope that helps a little.
don -
thanks don for ur help . i have solved the solloution, now my line in card (sound card)works 2 in 1 .i brought a v jack with one male and other 2 female male jack goes in line in (soundcard) other 2 female are there , one female goes my tv tuner card sound and the other female goes my camcorder audio sound plug(svideo has only video no sound) u have to connect ur camcorder or vcr sound in line(sound card) (bottom line souncard works 2in 1)take care thanks again
[/img][/url]
pinnacle pctv 310i
By marc21782000 in forum Capturing and VCRReplies: 10Last Post: 4th Jan 2010, 03:30 -
What software for Pinnacle PCTV HD?
By tomreedtoon in forum Capturing and VCRReplies: 10Last Post: 9th May 2009, 07:14 -
Pinnacle Studio PCTV upgrade?
By visionman in forum Newbie / General discussionsReplies: 6Last Post: 7th Jan 2009, 14:41 -
Audio problems with Pinnacle PCTV HD Pro Stick.
By cactusjack310 in forum AudioReplies: 0Last Post: 21st Jan 2008, 18:16 -
Pinnacle PCTV USB 2 - Vista
By hellybelly in forum Capturing and VCRReplies: 0Last Post: 30th Oct 2007, 04:20
