I been having trouble with DVD2svcd lately. it doing ok until the process of where besweet is, the audio concersion process if i'm not mistaken. When besweet run, window gave me a an error and after i click dont sent on the error window, besweet just close and report in the log window of dvd2svcd that audio conversion finished. i checked the file Encoded_audio_1.mp2 and the size is 0. The process then just finish like always but it didnt create any bin or cue file. so the program said that it's done but it's not successful. Below is my log file, i'm not sure if it can help. Anyone know how to fix this? thanks.
Window error:
AppName: Besweet.exe
Appver:0.0.0.0
ModName: mp2enc.dll
ModVer: 0.0.0.0
Offset: 000a371
Log File:
WNASPI32.DLL 4.6.0.1021
Key found: E4160102C3
- 4/18/2003 9:58:51 PM
- DVD to SVCD Conversion
- DVD2SVCD ver. 1.1.3 build 2
Initializing
Initializing finished.
- 4/18/2003 9:58:55 PM
- Free on drive I: 11891.47 mb
- Internal rip
Preparing vobfiles to be ripped:
- H:\VIDEO_TS\VTS_01_1.vob
- H:\VIDEO_TS\VTS_01_2.vob
- H:\VIDEO_TS\VTS_01_3.vob
- H:\VIDEO_TS\VTS_01_4.vob
Ripping: H:\VIDEO_TS\VTS_01_1.vob
Ripping finished. Speed: 1739
- 4/18/2003 10:03:16 PM
- DVD2AVI
Creating DVD2AVI INI file:
- C:\Program Files\DVD2SVCD\DVD2AVI\DVD2AVI.INI
Variable settings:
iDCT_Algorithm: 32-bit SSE MMX
Executing DVD2AVI.
Executing DVD2AVI. Commandline:
"C:\Program Files\DVD2SVCD\DVD2AVI\DVD2AVI.exe" -CS=2 -YR=1 -EXIT -OF=[I:\DVD Rip\2 Chapter Test\DVD2AVI_Project_file] -IF=[I:\DVD Rip\2 Chapter Test\VTS_01_1.vob]
Analyzing DVD2AVI Project file
Hybrid Film activated. IVTC will be applied and will slow down the entire process!
Framerate: 29970
DVD2AVI processing done.
- 4/18/2003 10:05:50 PM
- Free on drive I: 11449.70 mb
- AUDIO Extraction
Found AC3 stream id: 0x80
Filename: I:\DVD Rip\2 Chapter Test\Extracted_audio_1.ac3
Audio1 delay: -67 ms
Audio extraction finished.
- 4/18/2003 10:08:21 PM
- Free on drive I: 11434.33 mb
- AUDIO conversion
Encoding Audio. Filename: I:\DVD Rip\2 Chapter Test\Extracted_audio_1.ac3
Executing BeSweet. Commandline:
"C:\Program Files\DVD2SVCD\BeSweet\BeSweet.exe" -core( -input "I:\DVD Rip\2 Chapter Test\Extracted_audio_1.ac3" -output "I:\DVDRIP~1\2CHAPT~1\Encoded_audio_1.mp2" -logfile "I:\DVDRIP~1\2CHAPT~1\Encoded_audio_1.log" ) -azid( -L -3db -c normal -s surround -g max ) -ota( -d -67 ) -2lame( -e -b 192 -m s )
Audio conversion of I:\DVD Rip\2 Chapter Test\Extracted_audio_1.ac3 finished.
Audio conversion finished.
- 4/18/2003 10:10:52 PM
- Free on drive I: 11434.30 mb
- Video Encoding using TMPGEnc
- Encoding I:\DVD Rip\2 Chapter Test\AviSynth_Script_file.avs
StreamSectors: 771186864
AudioSectors: 16451596
VideoPAPO: 11691252
ScanOffsetBytes: 14486
SeqAligningBytes: 920634
DVDBytes: 0
VideoEndHeader: 4
SubtitleSectors: 0
EmptySectors: 238.00
PictureSectors: 1.00
PureMPEGStream: 742108892.50
Seconds: 676.30
CalcMPEGStream: 742108892.50
Frames: 16095
CDSize: 740.00
Number of CDs: 1
Cut point 735.00
Using CQ Value: 80.00
Executing TMPGEnc. Commandline:
"I:\DVD Ripping Tools\TMPGEnc Plus 2.53.35.130\TMPGEnc.exe" "I:\DVD Rip\2 Chapter Test\TMPGEnc_Project_file.tpr" /Encode /Close
Video Encoding finished.
- 4/18/2003 11:47:48 PM
- Free on drive I: 11317.75 mb
- Converting Pictures from ES to PS
Saving bbMPEG settings: C:\Program Files\DVD2SVCD\bbMPEG\default.ini
- 4/18/2003 11:47:50 PM
- 4/18/2003 11:47:53 PM
- 4/18/2003 11:47:55 PM
- Multiplexing and cutting
Offset in Seconds: 2
Executing bbMPEG.
Variable Settings:
Movie offset: 2 seconds
Cut point: 735 mb
Executing RunbbMPEG. Commandline:
"C:\Program Files\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "I:\DVD Rip\2 Chapter Test\bbMPEG_Muxed_File.mpg"
Multiplexing and cutting finished.
- 4/19/2003 12:03:08 AM
- Free on drive I: 11317.73 mb
- Determining length of audio
Analyzing finished.
CD-Image creation finished.
- 4/19/2003 12:03:15 AM
- Free on drive I: 11317.72 mb
- SVCD Creation finished!
i had that prob too...
had to get the .mp2 from another program (i used vob2audio), went back into DVD2SVCD (recovery mode) demux part (i think it was that one) and
recovered it from there...
...but that was only for 1 dvd...hope this was the answer you were looking for.
besweet, belight
By volam in forum AudioReplies: 0Last Post: 9th Sep 2009, 21:53 -
Besweet causing problems?
By hardcorejason in forum Video ConversionReplies: 1Last Post: 27th Apr 2008, 14:59 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 17:28 -
besweet 5.1 wav
By dvdfreak1971 in forum AudioReplies: 1Last Post: 11th Apr 2008, 15:44
