well, my TV acts kinda weird. On the left side it only crops a little, while it crops much more on the right >.<
I used Jürgen's picture to show the details.
How can I fix this ?
can it be fixed ?![]()
what kind of file are you doing?
is it in standard format size?
i had a simular problem with some pal files on my brothers tv, (i am in north america) and i solved this by changing the format on the dvd player, tv to ntcs and video to auto ajust.
you probaly want pal for tv, but auto for file format
does it happen with just this file or all vcd/svcd?
do dvds do the same thing? <<this one, if so your probaly screwed
what did you use to make the mpg file?
oh sorry.
I forgot to mention it was about the Mpeg still I make using VCDeasy.
I did them in NTSC because all my clips were.
My DVD standalone player supports all regio code.
hmm for some reason the attached image didn't show up.
I'll try uploading it again.
EDIT: whoops, forgot to type the code
EasyCAP on STK1160 cropping problem
By amex in forum Capturing and VCRReplies: 0Last Post: 15th Oct 2010, 05:43 -
Video cropping problem
By KillEmAll007 in forum EditingReplies: 6Last Post: 31st Dec 2009, 21:06 -
Pinnacle Studio 11 - Problem with cropping video
By mjkamish in forum Newbie / General discussionsReplies: 2Last Post: 28th Dec 2008, 16:51 -
FFDSHOW Problem, Cropping Video. See the photos I took!
By Xenogear900 in forum Software PlayingReplies: 5Last Post: 1st Sep 2008, 11:15 -
Problem when cropping avi
By baconharvester in forum EditingReplies: 2Last Post: 15th Sep 2007, 19:43
