Hi guys, hope you can help me again. New problem has just emerged for me! It's audio lagging behind slightly and a jerky video.
I capture Analog NTSC tape using Adobe Premiere 6.5 and convert to mpeg2 (for SVCD) using TMPGEnc. The movie is long and so I use TMPGEnc 2.510 to do three batch jobs at the following frame intervals:
1. 17 to 57500
2. 57500 to 107815
3. 107815 to 154372
The TMPGEnc settings are:
>> Source Range - audio gap correct '0' sec
>> Noise Reduction - '20', '1', '10', 'enable filter'
>> Other Settings > Video - '2 pass VBR', 'interlace', motion 'high quality slow'
>> Other Settings > Advance - 'interlace', 'bottom field B', '4:3 525', 'full screen', checked boxes for 'source range', 'noise reduction', 'sharpen edge', 'simple colour correction'
>> Bitrate Setting - average bitrate '2520'
I viewed the mpeg-2 files created on PC as well as encode into SVCD and both produces jerkiness and audio sync problems.
What have I done wrong? Is it because I checked the boxes for 'sharpen' edge', 'simple colour correction', average bitrate of '2520' instead of '2519' or the batch job frame intervals?
I can trial and error but it takes too much time. Each 5 min encoding takes up 30 minutes! I really hope someone can help me asap.
Thanks,
Halley, Singapore
Results 1 to 1 of 1
Software:
Adobe Premiere Pro - capture stills & motion, edit, render
Adobe Photoshop 7.0 - edit stills
TMPGenc Plus 2.5 - encoding, splitting mpeg
VCDEasy 1.1.5 - stills to mpeg, interactive menu, SVCD cue/bin
MOTV 2.10
Nero 5.5.8.2 - burn image
MKV stream extraction causing audio sync problems
By PlanetIndigo in forum Video ConversionReplies: 18Last Post: 29th May 2011, 22:07 -
Avidemux editing causing audio sync issue
By perdomot in forum EditingReplies: 0Last Post: 14th Sep 2009, 15:29 -
Glitch In Video Causing Audio To Off-Sync
By Squid_uk in forum Newbie / General discussionsReplies: 2Last Post: 2nd Nov 2007, 10:51 -
audio sync prob dazzle dvc-150 and virtualdub
By zephxiii in forum Capturing and VCRReplies: 5Last Post: 30th Jul 2007, 13:34 -
audio sync prob AFTER burning !
By bluraid in forum Newbie / General discussionsReplies: 5Last Post: 21st Jun 2007, 05:28
