    Dec 2002
    how do i replace an audio in a divx with another audio file?
  2. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    use Virtualdub - load your divx, then under Audio, select WAV Audio and select the audio file you want to use instead of the regular audio.
    Then Save As a new file.
    - housepig
    Dec 2002
    the audio is avi format i don't think i can use this with virtual dub
