hello![]()
I capture video with virtualvcr directly to DivX 5 and I don't have problem with sync.
But after convert to mpeg with TMPGenc I have audio delay of 1 seconds.
Why?????
nib :))
Are you using the audio sync check when you are encoding your files? Its only available when you are in manual mode, not in wizard mode. This option will more than double the time of encoding, but will stop any audio sync issues your having. Search the TMPGenc help files for this feature if your not aware of it. It should explain what it does and how to use it.
Nib,
Did this fix your problem?
I'm having a similar problem with demuxing a TV video capture with TMPGEnc. Audio out of sync. Wonder if the "sync audio" feature is the way to go, or if I've got an NTSC vs. PAL issue. My video seems to be running too fast, which leads me to believe I chose the wrong format...
Thanks,
Eph -
cephraim
You can use avicodec to find out what kind of format the tv show is in. It can handle avi and mpg files. When you load the film it will tell you he resolution, bitrate, fps, etc. It is available in the tools section of this web page under other useful tools. Also where is the audio sync function in TMPG. I searched the help files and came up with nothing. -
Hello again!!
No, I can't fix the problem.
I search parameter of audio in TMPGenc and i can't find anything for to resolve that problem (audio sync.). I try every parameter possible and the problem continue.
I'm going try to find the soluction to resolve that problem.
And another thing: I'm sorry my English
By
nib :)) -
FYI, I gave up on the TMPGenc/IFOEdit method.
Found Ulead's Movie Factory 2.0 does EXACTLY what I want all-in-one.
Even provides an automated way to add a menu with chapter selection capabilty.
Very nice.
Eph
SOLVED:Mpeg2 Video (Movie cilp) to PAL DVD - sync prob using DVDFlick.....
By bahjan in forum Video Streaming DownloadingReplies: 0Last Post: 20th Aug 2010, 10:03 -
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 09:32 -
Video has a ripple effect whith any movement?
By David9799 in forum Software PlayingReplies: 4Last Post: 13th Aug 2009, 18:35 -
audio sync prob dazzle dvc-150 and virtualdub
By zephxiii in forum Capturing and VCRReplies: 5Last Post: 30th Jul 2007, 13:34 -
audio sync prob AFTER burning !
By bluraid in forum Newbie / General discussionsReplies: 5Last Post: 21st Jun 2007, 05:28
