ok. if a 69 minute vcd at the standard bitrates (say 3 episodes of a 23 minute TV show joined together) will end up being about 690-700 mb large, how much time can i fit for an SVCD at the standard bitrates (2520 CBR,224kbps audio) that is less than or equal to 696 MB?
My calculator told me:
Audio: 224 kBit/s
CD-Size: 700MB
Bitrate: 2506 kBit/s
Time: 40 Min -
You can use a calculator as thewolf just did. They are available in the tools section of this website. A very easy one to use if you encode at constant bitrates is the Bearson bitrate calculator available at www.doom9.org.
it that what the actual file size will be or the cd type is will fit on. i've fit up to 805 mb on a "700 mb" cd before. is there a calculator that I can choose my target filesize output.
Most of them let you specify a target size, either in minutes, media, or in actual file size. Why do you need to specify an actual size? Is this for a DivX encode? File size is somewhat irrelevant for MPEG VCD/CVD/SVCD as you already seem to realize. The length of MPEG that will fit on CD-R is determined by the average bitrate.
Just try any of them, select your target media (650MB, 700MB, 900MB, DVD-R, etc). Plugin the number of minutes and the number of discs you want to put it on, and it will give you the average bitrate to use when encoding.Impossible to see the future is. The Dark Side clouds everything...
How to split a .TS video file based on time (not file size!) ?
By Michael REMY in forum EditingReplies: 4Last Post: 19th Sep 2020, 18:32 -
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 17:29 -
File size problems when playing from USB?
By BBQchicken in forum DVD & Blu-ray PlayersReplies: 8Last Post: 16th Nov 2011, 18:26 -
Question: MKV File Size vs MP4 File Size
By VideoNoobz in forum MacReplies: 6Last Post: 20th Feb 2010, 02:44 -
Editing Avi header file and playing time.
By Abrus in forum Video ConversionReplies: 2Last Post: 12th Jul 2007, 10:48
