  1. i still seem to get audio sync problem even though i seperated audio as Wave using virtualDub and encoded using TMPGEnc as per as the guide on it.
    and yes it gave me that error about something about vbr thing while opening it in vitual dub for audio sepration
    can any one plze help me
    this my 4th time
    Dec 2002
    Texas USA
    Most of us need complete sentences and details to help. We're not there to see ourselves. Ask again please, and I can try to answer if I understand what you're wanting.
    I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored.
  3. sorry txpharoah really sorry
    the problem is as follow
    i have this downloaded movie 701mb file which i want to convert to vcd or svcd, so i used the divx to vcd guide available in the " HOW TO" section
    to avoid the audio sync problem i sepereated the audio to wav using VirtualDub, i still seem to get a video before audio problem
    forgot to tell u that when i opened the divx file in VirtualDUb this window came up about detecting a improper vbr audio encoding and ........
  4. is the audio sync problem on the avi? have you deleted the bad frames?
  5. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    To remove bad frames:
    There's this: https://www.videohelp.com/forum/viewtopic.php?t=152458&highlight=idiots+guide
    or this: https://www.videohelp.com/forum/userguides/153907.php
    or this: https://www.videohelp.com/forum/viewtopic.php?t=142555
    Take your pick!
    To create a wav file when you get a VBR warning, or if the audio is AC3, use Goldwave. Load the Avi, save, that's it.
    8)
