    Apr 2002
    N.London, UK
    The badframes.log produced by VDub-MP3 is time-consuming to scan through when looking for the start & end positions of each group of bad frames.
    So I wrote a small program to make this easier.
    Hope you find it useful.
    it is here: http://homepage.ntlworld.com/mdipol/bfg/
    Feb 2003
    Ontatio, Canada
    After download it wont run due to a file missing .... looks like a usefull program try again would like to try this..
    Apr 2002
    N.London, UK
    what is the file that it says is missing?
    Feb 2003
    Ontatio, Canada
    A warning window that say's MSFLXGRD.OCX is missing or one of its dependencies..
    Apr 2002
    N.London, UK
    OK. I've put the file MSFLXGRD.OCX on my webpage.
    Download it: http://homepage.ntlworld.com/mdipol/bfg/MSFLXGRD.OCX
    Copy it into folder: c:\WINDOWS\SYSTEM32 (or c:\WINNT\SYSTEM32)
    Sorry about that.
    Let me know if it falls over again.
    Feb 2003
    Ontatio, Canada
    Thanks Marco, Tried again and its working but another message this time says that there is no c:\badframes.log does not exist ???.
    What Virtual Dub are you using ??.
    I'm using 1.5.1 and no bad frames file is generated after the scan.
    Am I missing something here ???.
    Thanks for your quick replies...
    Apr 2002
    N.London, UK
    You need to use a specially modified version of VirtualDub.
    It is called 'VirtualDub MP3 Freeze'.
    You can download it from the Tools section here.
    When you use it to check for bad frames, open your .avi file, select 'Video' and then select 'Check Video for Freezes...'.
    When it has finished it will have created file c:\badframes.log and you can run the badframes.exe program.
    Feb 2003
    Ontatio, Canada
    Thanks Marco, Both are working fine now.
