  1. I've just wiped my hdd and reinstalled with WinXP for the first time and I'm having some problems with the audio on my Winfast 2000XP card? It's mostly to do with the audio, running the software seems to adjust my system audio, and I can't seem to adjust the volume on the Winfast software smoothly. Also, after a few mins of watching Live TV the audio goes completely and I have to restart the software?
  2. Deaks,
    Could you give us an idea of your system config
    Dec 2002
    Texas USA
    You search the Winfast (what is that anyway?) website for bugs reports, drivers updates, etc. Can you really use XP with it? Maybe not.
    I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored.
  4. My system:
    Elite K7S5A mobo
    AMD XP2000 cpu
    SB Live 1024 Plat. sound
    GeForce 4 Ti4200 graphics
    Leadtec Winfast 2000XP Deluxe TV/vid capture
    Just put in that SN Live 1024 in plave of a SB 16 PCI and the volume problem seems sorted. But I still lose sound after a couple of mins?
