I cannot get my DXR3 to play SVCD`s.
Can anyone help. I used Nero to burn the SVCD but should i
be using something else.
Or is it not possible for the DXR3 to play them.
I`m on Win2K P3 667MHz 256MB RAM.
Help would be appreciated.
the DXR3 is a really a Real Magic Hollywood+, I suggest getting there drivers and software. I play svcds just fine
Is there any chance i can get the files off anyone as i cannot get hold of them.
Also full instructions for installation would be appreciated.
I`m desperate to play SVCDs on my DXR3.
http://www.creative.com/support/files/download.asp?prod=encore&OS=Win98®=0&select=Get+Files
Say Thank You,
Da Kitty -
Thanks Da Kitty,
I knew about these drivers and notice im running Win2000 which isnt mentioned on the download details.
Also as previously shown Hollywood plus are the drivers i require. -
1.)
updateddrivers could help.
2.)
Dxr3 does play ,all vcd's, xvcd's, xsvcd's,sxvcds, lvcds, mpgz etc.
3.)
on my card svcdz dont autorun, i have to browse for the mpg2 mpg file, the card will then cue it up n play it.
zTr -
Ok thanks for the info.
However the DVD player says "unknown format" when i try and run it.
Which burning software do you use.
I used Nero (latest version).
Regards -
becuz of my burner recognizing probz i stuck to nero 5.04 or whatever the latest one was before 5.5 came out.
Normally, it burns svcd's wit no probz.
What player are do u have? Is it the creative one?
Have u tried windvd or powerdvd, elegard or sthsvcd?
The latter two are share/trialware/freeware i believe.
Wat's the bitrate on the svcds you cookin' or burnin'?
If you are, encoding, what encoding app and wat settings are setup?
ztr
Having PROBs with internet connection, this is what I've done so far. Help!
By jacknscoob in forum Off topicReplies: 10Last Post: 19th Feb 2012, 03:37 -
I'm having probs with MPC-HC
By HartsVideo in forum Software PlayingReplies: 8Last Post: 10th Feb 2011, 20:47 -
A few probs with FAVC
By kronick in forum Video ConversionReplies: 9Last Post: 15th Oct 2008, 19:25 -
dvdx sync probs
By zookeeper525 in forum DVD RippingReplies: 0Last Post: 17th Aug 2007, 20:29 -
Avi conversion probs
By hitmanhill in forum Authoring (DVD)Replies: 15Last Post: 12th May 2007, 08:21
