  1. Hi!
    Since I'm very much a newbie, I thought i'd post a question here.
    I've been following this guide here trying to sort out a sync problem. According to the guide Goldwave should be used. I tried to insert silence since the audio was before the video, about a second.
    In the insert silence box I wrote 1,000, but that only made the mpeg file even more out of sync. Isn't 1,000 the equivalent of 1 second?
    By the way, does anyone know of an easier way to deal with sync problems?
    I'd be grateful for an answer.
    Nille
    Apr 2002
    The State of Frustration
    Actually, you are on the right track. I do not know if there is an american and a European version of the same program. The point is, since this an American program, enter 1.000, not 1,000. The difference being is we "Yanks" use the decimal point where Europeans use the comma when numbers are concerned.
    Hello.
  3. Thanks, i'll try that
