Hi All,
Is there any easy way to convert a DVD (.vob) to an Audio + Video system file (mpeg, mpg, etc.). I would like to be able to open the converted file in Ulead Video Studio or Canopus ProCoder. Thank you very much for your help.
HHmm..A VOB file IS an mpeg file already and you should be able to open it ok in most softawre. A VOB file is just Mpeg Video (normally mpeg-2) multiplexed with audio (Normall dolby digital ac3).
Thank you very much txpharoah,
I tried VobEdit and demux the Vob file but still it extracts the vob into two separate files (i.e. m2v and AC3). Is there any way to get just one file containing both video and audio with an extention other than vob that for example Canopus ProCoder can open it?
How to convert the 1gb VOB file to 80Mb AVI file ?
By zohaibshaikh in forum Newbie / General discussionsReplies: 3Last Post: 17th Oct 2010, 06:41 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 17:12 -
Using ffmpeg command line to convert a .vob(DVD) to avi/mpeg
By alfo666 in forum Newbie / General discussionsReplies: 1Last Post: 13th Sep 2009, 03:14 -
How to Convert VOB file from DVD with ignore read errors
By designbuyers in forum Video ConversionReplies: 3Last Post: 27th Jul 2009, 09:17 -
How to convert IFO/ Vob to mpeg (sony DVD camcorder)
By Guthix in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd May 2007, 18:05
