  1. I burned a DVD–R and it plays damn good
    on my computer–almost a little too good.......
    It wont play on my DVD player though.
    I have a Samsung N–501, which according to
    this website is DVD–R compatible.
    Did I maybe do something wrong when
    I burned it?
    Used OSEx to rip,
    Sizzle to create,
    and Toast to burn.
  2. Member WiseWeasel's Avatar
    Jan 2003
    Silicon Valley, CA, USA
    It often depends on the type of dvd-r media you use. The computer based dvd burners are very compatible w/ all media, but commercial dvd players will often fail to read many types of media. I've had good luck with Princo white-top dvd-r media, which is (relatively) cheap and very compatible. Ritek media is also supposedly quite compatible, although I have not had a chance to try it out. Try different brands until you find a good one, and stick to it. It might also be a problem with Sizzle dvds, which have been reported to have problems with many dvd players. Hope this helps. . .
    I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systčmes, le cas d'application excepté."
  3. found some Princo and Ritek DVD-R's for pretty cheap on the web.
    But there are different prices. Can I go with the cheap ones
    or should I spring for the more expensive ones? Also what is
    the difference between a regular DVD-R and and authoring
    DVD-R?
