What's the difference between "Quick Erase" and "Full erase" for DVD-RW?
I don't know which one to choose. Full erase takes a long time. It's like saying if you have time to spare then choose "Full erase" if you're in a hurry then choose "Quick erase".
What do they mean by completely erasing the disk with "Full erase". Is it like files will be hidden but still there when you "Quick erase"?
Yes Quick erase Just removes referance to the files, but they are still there taking up space. Full erase completly formats disk.
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
When I erase my RW disks, I always choose quick erase and it has never failed on the subsequent burn to that disk.
Once it erases the reference files and such it doesn't know about the other data on the disk, so it just writes over it...
If you are going to write over the disk, just use quick erase...Use what works for you... -
Hi Txpharoah
Just read your reply to this post above and also about using sticky labels on DVDs. I'd just like to say how refreshing it is to read your professional replies and helpful advice. It's a nice changePlease stay around
Guess what my plans are for Easter? Reburning a couple of dozen labelled DVDs onto new blank DVDs that certainly will not be getting labelled. Yes I am learning the hard wayBut there is a bright side. Since burning these dozen or so DVDs I have been learning how to use DVD Lab, and producing some very nice up-front Menus with my own imported jpegs as backgrounds, and even Menu music. So the reburned DVDs will look even better than the originals. Who cares if they don't have labels !!! It's what you see on-screen that really counts
Best wishes
Zenzen
Brisbane Australia
Is it possible to erase a DVD+R?
By Han Solo1 in forum Newbie / General discussionsReplies: 5Last Post: 18th Aug 2010, 13:54 -
How to erase a DVD-R disk
By bryankendall in forum ComputerReplies: 5Last Post: 24th Dec 2009, 13:16 -
DVD RW wno't erase
By jollyjohn in forum Newbie / General discussionsReplies: 5Last Post: 20th May 2009, 10:32 -
Can't erase my DVD-RW disc
By hurtstotalktoyou in forum DVD & Blu-ray WritersReplies: 4Last Post: 15th Nov 2007, 09:40 -
HELP - Can`t erase 10 dvd rw discs
By LOWTECH in forum DVD RippingReplies: 6Last Post: 13th Aug 2007, 14:28
