HELP i cant even do anything in the program with out errors and i havent changed anything i even re installed in new folder etc. i even went to the extreems of re installing windows. I get memory low when opening stream and numerus errors in ntdll.dll HELP are there any other program that will let me encode VBR Mpg as easy as this will??? or does anyone know how to fix this
Andy
If a computer Bites you BYTE it back -
What are your PC specs ? also, there are plenty of other encoders out there!
for example DVDx can encode, and MainConcept has a great quality encoderEmail me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
Sorted it now something to do with the xvid codece the video was using just used virtualdub to fast recompress to make it divx and then its fine it just makes the whole process and hou longer but i dont mind. i couldnt see my computer being a problem AMD 1333 1024 ddr 2700 memory and 160GB hard drives
Andy
Where is the Major... ??
By moon47usaco in forum ffmpegX general discussionReplies: 2Last Post: 12th Aug 2010, 13:22 -
how can i download a major editor?
By maltesefalconese in forum EditingReplies: 4Last Post: 4th May 2010, 12:37 -
Need Major help from an expert!
By jbartosh in forum MediaReplies: 38Last Post: 23rd Oct 2007, 13:45 -
Major Problem with AVI
By thepcpitstop in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 6th Jul 2007, 12:49 -
major problem
By Antitrust19 in forum ComputerReplies: 6Last Post: 28th May 2007, 09:30
