I was wondering if you took a couple seconds from a mpeg, could that be used as a motion menu in VCDEasy?
If that's possible would I also be able to use sound?
Thanks for the help.
If everything is infinite then nothing is definite.
2 ways I make my menus.
1. A series of still shots that simulate a cursor moving around.
2. A moving picture with audio intro that lists options but with no cursor control
audio with Option 1 would restart/change with each still shot. -
i usally use tmpg to cut the intro sequence of the movies title so you get the opening title with sound. and use that as a intro file on tscv
i have also used a single frame cut out with powerdvd of the chapters, puting all of the chapter pics on a background. and then take a loopable sound with that into tmpg and go a menus with sound.
i usally use 10sec of sound and in svcd its makes out to be 5 mb each
i use the same still pic with a 10 second audio clip, run thru tmpg, for scene selection menu 1 starts movie , 2 scene selection.
and finally the same for insert disk 2.
this is a great guide to motion menus
http://home.att.net/~adam.poole/Introduction.htm
multiAVCHD menu background and chapter thumbnail creation
By Delta007bhd in forum Authoring (Blu-ray)Replies: 12Last Post: 7th Dec 2016, 08:19 -
DVD & BluRay Menu + Chapter Creation Programs ?
By VideoFanatic in forum Authoring (DVD)Replies: 4Last Post: 2nd Oct 2011, 22:06 -
Simple Menu Creation
By Nanorip in forum Authoring (DVD)Replies: 0Last Post: 23rd Nov 2010, 23:36 -
Menu Creation in DVDAuthorGui
By larrytxeast in forum Authoring (DVD)Replies: 3Last Post: 23rd Jul 2010, 11:52 -
DVD menu creation
By andrewgerm in forum Authoring (DVD)Replies: 4Last Post: 28th Aug 2008, 15:24
