I am trying to convert several movies from .avi to mpeg2. I have tried several programs and one porblem I keep seeing is that the picture seems like it is "squeezed" after its converted. By that I mean everything looks slightly "narrower" or not quite wide enough. Any ideas what settings I need to adjust?
Also, with TMPGEnc I am losing the sound upon conversion. I don't know whats going on but it seems to only happen with this particular program. I tried extracting the audio in videodub and then putting it back into an avi file and using that but it didn't help.
Any ideas?
BTW.....this forum is definitely for me because I'm a noob to all of this so bear that in mind
Is the source 16:9? If so, change the source in tmpgenc to widescreen, and make sure you have the codec for the avi installed. Also check the tools section for Tmpgenc codecs needed to convert certain files. Or, you can just look at one of the guides for AVI > MPG.
"Mustard?! Don't lets be silly now. But lemon, thats different, thats nice." - The Mad Hatter
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 11:30 -
Help needed with Avi2dvd "hiccup" (muxed mpeg2 avail but didn't f
By bgart13 in forum Video ConversionReplies: 2Last Post: 17th Apr 2008, 18:54 -
Review "HYFAI" MP3/MP4 "Nano" clone from ebay
By NG in forum Portable VideoReplies: 29Last Post: 18th Sep 2007, 06:45
