Hello, I have downloaded a few ISO's and burned them to DVD's. They seem to have the original menu but non of the extras work. How is this done? I backup all of my DVD's with DVD2ONE and have no problems but would really like to have the real menu.
Thanks!
this is the most popular question since i'm here (2 weeks) and still no real awnser..
So far, DVDShrink make this if you compress all the extra to still movie.. -
newest verion of DVDF2ONE 1.11 has full disc option and it backups a complete copy of the original, DVDxCOPY does also but most will be split to 2 discs, at least DVD2ONE just transcodes to one disc just a little less quality.
There have been several answers (check the DVD Rip guides to the left). You have two basic choices:
1) Transcode: DVD2ONE, DVD9to5, DVDShrink, etc.
2) Re-author: Instant copy, or try this guide:
http://www.doom9.org/mpg/maestro2.htm
The transcoders are fast (normally 15-25min) but the quaility sucks (YMMV some find the quaility to be fine and many 'claim' they can't see a difference between the transcoded output and the original video). Re-encoding gives MUCH better quaility (esp if you use the above guide with CCE or TMPGenc) but takes time (3-8hrs depending of settings, filters, CPU, etc).
DVDShrink is freeware, you can d/load it from doom9.org -
Actually, Instantcopy does it too. I tested it with Star Trek DS9 Disc 1 and wanted to put 2 eps on 1 DVD at 100%. I thought it was just going to put the episodes on there, but when I played it, it started with the menu that's on the original dvd.
And yes, the only working buttons are ones that link to the 2 eps, none of the others work, they're selectable, but they don't do anything. Frankly, I thought it would freeze up my dvd player, but it didn't.
Now if there could be a way for Instantcopy to give an accurate reading on the transcoded filesize. I have a 5.35G movie and shrink it at %99.9, it gives me a final size of 4.15G
I've used DVDshrink on several discs.
Some I can tell are transcoded (re-encoded).
But surprising, some discs I can't tell. I ran a DVD5 backup of LOTR:EXT ed. discs 1 and 2, and I can't tell a difference. I removed the AC3-6channel and level 3 encode, and I can't tell. And I'm picky and do some of this for a living. I can't tell. At all. It was impressive to say the least.
I like it better than DVD2One, so far at least.I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored.
+1 audio steam to the DVD with original menu.
By kurochocho in forum Authoring (DVD)Replies: 0Last Post: 12th Jul 2011, 11:48 -
Original DVD Menu
By cavusozkan in forum Authoring (DVD)Replies: 8Last Post: 17th Feb 2010, 22:54 -
how to keep original menu and not re-encode files by dvd authoring
By deejay.2001 in forum Authoring (DVD)Replies: 8Last Post: 1st Sep 2008, 03:08 -
Removing scenes from DVD while keeping original Menu?
By saini in forum Newbie / General discussionsReplies: 1Last Post: 25th Oct 2007, 23:42 -
Add a new audio stream to dvd and keep the original menu
By CostasGR in forum Authoring (DVD)Replies: 2Last Post: 15th May 2007, 05:33
