I looked on the compatibility list and by all accounts, it can play VCDs. But when I put my VCD in the player, it doesn't play, giving me an error about how it doesn't support that disc type. I'm pretty sure the disc itself isn't the problem because I can play it on my computer. Thanks in advance.
Closed Thread
little advice, newbie: don't post the same question more than once. especially if you're just starting out. i see all of your posts are the exact same question.
His name was MackemX
Please don't cross post.
https://www.videohelp.com/forum/viewtopic.php?t=154040
panasonic dmr e85h no audio/won't record
By janeydoll in forum DVD & Blu-ray RecordersReplies: 2Last Post: 30th Mar 2011, 17:13 -
Panasonic DMR ES46V Remote Won't Work
By melvid in forum DVD & Blu-ray RecordersReplies: 12Last Post: 5th Sep 2009, 19:57 -
Panasonic E100H won't read disks
By mfaust1071 in forum DVD & Blu-ray RecordersReplies: 7Last Post: 22nd Dec 2008, 20:01 -
I want to play VCDs on my laptop
By Michel-lyn in forum Software PlayingReplies: 2Last Post: 22nd Dec 2007, 11:38 -
I can not play some VCDs on my mechine. Can U help me ?
By wapw in forum Software PlayingReplies: 2Last Post: 21st Aug 2007, 12:46
