I looked on the compatibility list and by all accounts, it can play VCDs. But when I put my VCD in the player, it doesn't play, giving me an error about how it doesn't support that disc type. I'm pretty sure the disc itself isn't the problem because I can play it on my computer. Thanks in advance.
I own that player, and I play VCDS all the time, in fact, I just finished watching one.
Make sure you're using a half-way decent program like Ulead DVD MF 2. Do not use NERO
"Mustard?! Don't lets be silly now. But lemon, thats different, thats nice." - The Mad Hatter -
I also can play VCD on the DV31. It will NOT play SVCD.
Try disconnecting the power cord, then plug it in again. This resets the player. I also recomend DVD Movie Factory 2, also Neo DVDPlus 4 should work.
panasonic dmr e85h no audio/won't record
By janeydoll in forum DVD & Blu-ray RecordersReplies: 2Last Post: 30th Mar 2011, 17:13 -
Panasonic DMR ES46V Remote Won't Work
By melvid in forum DVD & Blu-ray RecordersReplies: 12Last Post: 5th Sep 2009, 19:57 -
Panasonic E100H won't read disks
By mfaust1071 in forum DVD & Blu-ray RecordersReplies: 7Last Post: 22nd Dec 2008, 20:01 -
I want to play VCDs on my laptop
By Michel-lyn in forum Software PlayingReplies: 2Last Post: 22nd Dec 2007, 11:38 -
I can not play some VCDs on my mechine. Can U help me ?
By wapw in forum Software PlayingReplies: 2Last Post: 21st Aug 2007, 12:46
