  1. I upgraded from windows 98 second edition to windows 2000. After reinstalling premiere 6.5 I cannot import jpegs. When I go to the import dialog box everything shows but jpeg. I tried show all files and it still doesn't show. I tried reinstalling premiere and got the same results. Any suggestions?
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    did you remember to install qt also ?
  3. I installed quicktime from the quicktime website afterward. I got a return error of -1 when premiere was installing. Should I put quicktime on first before installing premiere?
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
    try it that way -- shouldnt have to , but maybe .. its the qt engine that handles tiff and other image formats within premiere , including jpeg i believe ..
    Dec 2002
    Texas USA
    I uninstall and reinstall Premiere 6.5 all the time. It's the best one yet, but buggy as hell. Try that once. In addition to the QT solution.
    I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored.
  6. Thanks, Installing quicktime first worked. Now everything works fine. Thank you for your help.
