I am trying to convert a 99 min movie from AVI to MPEG 1 or 2. The AVI currently is at 512x416 resolution.
What would be the best way to convert it to an MPEG? Would you suggest 1 or 2 and what resolution? Could I retain the resolution and bitrate(how do I determine the bitrate of the AVI?)? I'm looking for the best quality possible and for it to fit on 1 CD-R (800mb).
Thanks.
To fit it all on one CD you will need to go with mpeg1/VCD. You will be making an XVCD (VCD out of spec) which may or may not work on your player. The resolution will be the VCD standard and the bitrate will be whatever is required to fill the disk. It's not going to be great quality, you're really squashing it. Try it and see if it's acceptable.
Here's a guide: https://www.videohelp.com/forum/userguides/84759.php Skip the ripping part and go to the part where he opens TMPGEnc. In the guide he mentions 2-pass VBR, I recommend it for better quality.
8)
"Art is making something out of nothing and selling it." - Frank Zappa -
Thanks. It's an anime movie and it looks good enough for me on my Tv at 352x240 @ 917kbs. I can fit all of it on one disc
Help/Advice Converting .AVI Divx Files To ...
By MourningStar in forum Video ConversionReplies: 2Last Post: 12th Dec 2009, 17:18 -
Advice on converting TV recorded .TS to AVI or H.264
By doveman in forum Video ConversionReplies: 8Last Post: 22nd Apr 2009, 10:06 -
Problems converting AVI to vcd format using TMPGenc 2.5 Plus
By peterock in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 16:34 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 21:27 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54
