Almost all my DVD Backups wont play on my Daughters PS2 , OUT OF ABOUT 20 ONLY TWO WILL PLAY I have used the same media disks for them all and then tried other brands still the same outcome.
This is the Version Information on her PS2:
Console SCPH-30003
Browser 1.20
Cd Player 1.20
Play Station Driver 1.10
DVD Player 1.20E
Does it need updating if so are there any guides to doing this. I realize her Play Station is an early version can she upgrade it?
Regards Patsym1
you might want to try updating the DVD player. did you get the PS2 DVD remote? that comes with a DVD update to 2.10U. hope that helps.
its nothing to do with how you burn the dvd if some of the ones he's done work. I would say it'll be the laser in the playstation thats at fault, it may need replacing or it can be adjusted if you know what your doing.
Actually, I know for a fact that the method has EVERYTHING to do with it. If I backup DVDs in a certain way such as DVDDecryptor it will not work in my DVD player, but if i take a DVD compatible MPEG and author it, it works in my DVD player... Seems to me that those are two different methods that DO affect playability...Originally Posted by fatbloke
Where may I get the last version of the x264 - 64 bits version codec?
By daniel827 in forum EditingReplies: 5Last Post: 27th Dec 2011, 19:55 -
Mac version of VLC is less functional than the Windows and Linux version
By HitTheRoad in forum MacReplies: 12Last Post: 30th Oct 2011, 04:48 -
SUPER version 39 is broken - reinstall older version?
By castalla in forum Video ConversionReplies: 7Last Post: 3rd Nov 2010, 19:20 -
Indiana Jones Lego - PS2 version limited in any way?
By lordsmurf in forum Off topicReplies: 10Last Post: 8th Jun 2008, 09:33 -
where to download old version of dvd fab??? error in new version
By willhenderson in forum Newbie / General discussionsReplies: 1Last Post: 1st Dec 2007, 17:00
