When i import a avi into VD(Virtualdub) i get a message saying that there is 6110ms (example with made in manhatten) of skew. So i carryed on as normal and found thats the audio is VERY out of sync when i did a sample tmpenc encode. Are there any tutorials ior guides dealing with XVid. I mean does the 6110 skew mean that the audio is 6s out if so where do i put the 6s to i stretch the audio file an extra 6 sec or put it in the middle of begining please HELP! (im going XVid to DVD)
Andy
If a computer Bites you BYTE it back -
69 views in 6 hrs and no replys!
Andy
That's your mistake right there. VBR audio needs to be handled different from regular audio, it's not the Xvid giving you problems.Originally Posted by Andy149
Are you extracting a wav file from your source and using that as the audio input for your encoder? You should be, but you need Virtualdub-MP3 when the audio is VBR. Get VDub-MP3 from the Tools section, load your file, audio-full processing mode, compression-no compression, conversion-48KHz (DVD), save wav.
Alternatively you can use Goldwave, load your AVI,save.
8)
"Art is making something out of nothing and selling it." - Frank Zappa -
right usually i'd just rip the audio from the avi as a wav then import it into tmpenc thingi with the avi and make an mpg but now i need to be ripping the audio to an mp3? then convert it to wav
Andy
No, if you get a VBR warning then your audio is already MP3 encoded using variable bitrate (VBR). Regular Vdub can't handle the conversion to wav, Vdub-MP3 can. Just use Vdub-MP3 for the avi to wav conversion.
thanx man/woman (
) will reply with results lol
Andy
Couldnt get vDub-MP3 working properly (still sync issues) so i opened the avi in goldwave thingi and its fine now im encoding some more snipits to see if the sync is okay but everything is looking good THANX
Andy
Glad you got it!
VirtualDub/Xvid question: YV12 vs. XVID FourCC in the xvidvfw.dll driver???
By KneeRow in forum Video ConversionReplies: 14Last Post: 1st Aug 2010, 14:35 -
How to get Xvid encoding in VirtualDub
By Dr_Asik in forum Newbie / General discussionsReplies: 9Last Post: 25th Feb 2010, 11:31 -
Virtualdub can not open xvid
By quxote in forum Newbie / General discussionsReplies: 2Last Post: 31st Jul 2009, 01:11 -
win98 xvid and virtualdub?
By dridge in forum Newbie / General discussionsReplies: 3Last Post: 10th Dec 2007, 23:34 -
Converting DV (on PC) to xvid through VirtualDub
By Wills in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 11th Jun 2007, 18:10
