hello i ahve tried to convert mov to mpeg with tmpgenc but halfway through it freezes, i trird bink and smacker but that fins an error and cant complete the conversion, is there any program that can scan and fix mov files i think it has a few bad frames, i have quicktime pro but i cant find any thing about fixing the file, is there a sorenson 3 codec for virtualdub?
thanks
seeya![]()
i have figured out which frames are corrupt but i have no way of editing them out cause all the progs i use freeze on the bad frames.
please help!
thanks
I have a sound problem when encoding .mov to other format like .mpg
The video is crisp; but no sound after all. I'm using tmpgenc plus.
the strange thing is: i have a friend that succesfully convert .mov to .mpg with his PC.
His spec is just the same as I ; the differences just he using athlon xp 1.8Ghz ( mine is 1.6Ghz) and his ddr memory is 256Mb ( mine is just 128Mb).
.MOV conversion to .AVI and .MOV HD quality query
By Peewitisland in forum Newbie / General discussionsReplies: 3Last Post: 31st May 2011, 12:22 -
Need Some Help with MOV Please
By LegendaryLero in forum Newbie / General discussionsReplies: 2Last Post: 20th May 2011, 01:10 -
How to convert a 1.83 GB .mov to 1000 MB .mov?
By moiz in forum Newbie / General discussionsReplies: 6Last Post: 31st Mar 2010, 16:31 -
mencoder wont convert the complete file, mov to avi|mov
By bjornieB in forum Video ConversionReplies: 2Last Post: 19th Nov 2009, 08:42 -
VCD to MOV - no audio on FCP
By kj1983 in forum MacReplies: 3Last Post: 9th Jan 2008, 10:05
