i am capturing with mmc7 useing the huffy codec. excellent quality. encoding with tmpge, video bitrate vbr-2pass average bitrate 2650, max bitrate 2700, minimum bitrate 2400. audio set at 44100, stereo, bitrate 128. burning vcd with nero. vcd files play fine on my pc but on my apex600a the audio plays for 2-5 seconds then makes a split second pause and just continues this cycle. video is perfect and the audio is in line it just has those continuos split second pauses. any suggestions? should i change the audio bitrate? i deleted the original avi files so if i use the already encoded mpeg files and up the bitrate would that matter? thanks......
AnonymousGuest
Try putting your bitrate as 224.I had a problem with the audio and that sorted it out.
Audio skips
By tendo.kagwa@gmail.com in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 5th Jun 2011, 12:26 -
skips on a DVD
By avextraxjp in forum Newbie / General discussionsReplies: 1Last Post: 16th Mar 2009, 17:45 -
New Pioneer 115D audio stutters/skips badly
By Captain Satellite in forum DVD & Blu-ray WritersReplies: 27Last Post: 19th Jun 2008, 19:27 -
DVD skips like crazy.
By tmac2085 in forum Newbie / General discussionsReplies: 31Last Post: 13th Sep 2007, 07:55 -
MENCODER skips frames when dealing with MPEG-2 audio
By zuja9 in forum Video ConversionReplies: 2Last Post: 19th May 2007, 16:12
