Hi, I read a lot about people DV AVI in Premiere - saving as AVI - then encoding in TEMPenc. Normaly I encode with Adobe encoder (Main Concept), but I wanted to try out TEMPenc to see differance. I captured the AVI (via 1394) in premeire 6.5 as AVI Type2. The captured AVI will open fine in TEMPenc. After a lot of editing(transitions, multi video & audio tracks) and saved back to AVI Type2, it will no longer open in TEMPenc Plus 2.5. I can open it Ulead, MP,Powerdvd,and anywhere except TEMPenc or Vitualdub. It says can't open or not supported. The same AVI before editing opens fine. I opened the AVI in G-spot and it said the file is fine no errors. The only differance I can find is in the 4CC block it lists: dvsd/dvsd, the original lists just: dvsd. Also in the Type it lists: AVI. the original lists: AVI opendml.
DirectShow priority set correctly, and all codecs installed?
Hello. -
Tommyknocker',
Gspot said i have all codecs and no problems with file. How do you set DirectShow priority correctly?Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
read this guide:
https://www.videohelp.com/tmpgenc.htm#problems
read the Problems section which is after the Step 5 - Encode section
AVI files won't open in Avidemux
By Ahari in forum Newbie / General discussionsReplies: 28Last Post: 18th Mar 2025, 15:22 -
Edited DVD won't play on standalone 1yr old DVD player.
By Brooke2424 in forum Authoring (DVD)Replies: 2Last Post: 14th Sep 2009, 14:50 -
avidemux won't open a DV .avi file
By BrianK in forum Video ConversionReplies: 2Last Post: 14th Jul 2009, 11:10 -
TMPG DVD Author 3 won't open FVFW avi
By jasoncolz in forum Authoring (DVD)Replies: 0Last Post: 7th Dec 2007, 16:21 -
DVD to AVI HELP!! I need an AVI that can be edited in Adobe Premiere.
By nimdivino in forum DVD RippingReplies: 4Last Post: 13th Sep 2007, 19:35
