  1. How do I get Nero to recognize the mpg file. Need help learning as I go here.
    Feb 2003
    New York
    I'm pretty new myself, but in my [limited] experience, I believe you need one more step: you need a program like Maestro or an equivalent to compile your MPG file into IFO and VOB files. At the end of the compilation process, they usually wind up in a directory called VIDEO_TS. These are the files that Nero will recognize and burn to your DVD.
  3. Not shure what is your problem. You want to convert an AVI file to SVCD? If this is what you want to do you need the Nero SVCD plugin, otherwise you wont be able to do it. By the way you should use other program to convert you avi file, nero does not do a god job.
  4. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    You can burn as an SVCD with VCDeasy, it's free and in the Tools section.
  5. Actually what I'm trying to do is convert an avi file to an mpg so that I can burn it on to a dvd+r. What other programs besides dvd maestro what you guys recommend. Would isobuster or ifoedit work and if so how would I be able to do this?
  6. Member spidey's Avatar
    Apr 2001
    U.S.A.
    If your clips is encoded, proceed to here
    https://www.videohelp.com/author
    ~~~Spidey~~~
    "Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
